How to change the background color of a Tab Control from a VI
I use a Tab Control (from Containers), which by default has a grey background.
I want to change the background color programmatically, that is from a LabVIEW VI.
Anybody know how to do this ?
Jan Nielsen
Freelance system analyst and LabVIEW programmer
Message 1 of 15
(22,277 Views)
Use the F Color property of the Tab control to change its color programmatically. Smiley Wink
BTW, it is NOT the background color of the Tab; it is its foreground color. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 15
(22,273 Views)
Hi Jan,
you have to allow different colors, then use the page references and change the color. See the attached example.
Mike
Message 3 of 15
(22,270 Views)
Yes, that worked - thanks a lot both of you !
Jan Nielsen
Message 4 of 15
(22,260 Views)
I have LV 8.2
Your tab control has two color red and green, each color for each tab on the front panel
I only found my tab control in the "container" palette, and only one color for two tabs.
where do you find your tab control with one color for each tab
I like your tab control
Message 5 of 15
(22,028 Views)
It's the same control.  You have to "Allow Multiple Colors" in its properties to paint each tab a different color.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 15
(22,025 Views)
BTW, you have to right-click the tab controls edge, then select 'Advanced >'.  You'll find it there.
Or, you can do it programatically with property nodes.
Message 7 of 15
(22,024 Views)
ok i'm missing something here no matter how many things i have tried i cannot get the tab control to change color. i have set it for multiple colors it just doesn't want to change.
i tried duplicating the example in my vi but am having difficulty adding the page property node.
when i do have a property node that appears correct i cannot connect it to the tabctrl property node.
so basically what i wish to know is what step am i missing.
Message 8 of 15
(21,897 Views)
solved my problem
Message 9 of 15
(21,893 Views)
Okay i have a similar issue. How do you change system tabs color? I keep getting errors. Ended up moving to modern tab to make it work. But i like system tabs look better. Is there anyway to do it on the system tab?
- A minute saved is a Minute earned!
Message 10 of 15
(20,325 Views)
