How to change the display order of Boolean Array
I'm inputting an Hex number and want vi to display it as a Boolean array of indicators.
The LSB appears to be on the top if the array goes up and down or, on the Left most while going right and left.
As in Registers, the LSB is always on the Right most.
How do I change the order of this display 180 degrees, so that the LSB is on the Right?
Rafi
(2,600 Views)
Use the "reverse Array" from the array palette.
Ben
(2,597 Views)
