How to change the path for the other designed VI files location
Dear friend
 i got we i files which are designed by some X guy. when i am opening in my labvew 2012 its asking the pathe older one.
where i have to change this path.
Note : the vi files are working fine in other system
(2,809 Views)
Hi RRDY,
Click here Help guide for your issue
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(2,794 Views)
Resave the VI's that are showing changes.  The path to the subVI's that are listed in the dialog have changed.  Until you resave the VI's that call these subVI's, you will keep getting this warning dialog box.
(2,772 Views)
