How to change the sampling time in "Write to measurement file"
Hi all,
We  are using labview to process the signals from a lab GT. I have LV 8.6. The samples are being recorded every 0.01 seconds. However i donot need such a high sampling rate. I would prefer 0.1 seconds. But i donot know how to change the sampling time. Can someone please help me out?
(2,991 Views)
One of the method is to create a flag ,increment  with every sampleat 0.01 sec.
and then after flag is at  10 write it to  measurement file.
regards
Message Edited by shrekt on 10-09-2009 11:50 AM
(2,987 Views)
you could use the elapsed time function and hook it up to a case structure so that every .1 seconds you write your data to a file.
hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,973 Views)
also something like this may work:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(2,969 Views)
