How to change the tag alarm text at runtime?
I'm developing a DSC application in which I need to support multiple languages. The idea is that the user can switch between languages "on the fly" at runtime. I think I've got the language thing figured out, but how can I change the tag alarm text at runtime? Loading a different scf file would probably work, but I'm concerned about the time it takes to unload/load the scf file. Any suggestions? Thanks.
(2,877 Views)
What version are you using?
Robert
(2,877 Views)
Hi REM1,
The version is 7.0.
(2,877 Views)
Try the attached VI. It will not retroactively change any alarms but it should work. Let me know how it does.
Robert
(2,877 Views)
