How to change the time duration and sampling rate of Simulate Signal VI in the dialog box?
Hi alyh,
You can do so by changing the values in the "Signal"/"Timing" sections of that dialog (left half of that dialog window)!
What's the point of your question? That graph is just an indication of the simulated signal…
(957 Views)
