How to change the title of the dialog during runtime in LabView7.1?
I am creating one dialog,in that i want to change the title of the dialog based on the user information.
How can i do it in run time?
Please help me regarding this
Thanks and Regards
Meenatchi
(3,224 Views)
The yellow dialog boxes cannot have a custom title. (Maybe possible with win32 api not directly with LV)
You could create a subVI that acts as a dialog, this gives you all the freedom to do what you want with it.
André
André (CLA, CLED)
(3,221 Views)
If you create your own dialog box, you should set the VI.FrontPanel.Window Title property
Ton
My LabVIEW Ideas
(3,217 Views)
Can u tell me the procedure to do this??
(3,214 Views)
There are different.
1. When the application calling the Dialog should continue running, use a dynamically started dialog.
2. When the application may halt execution until the dialog returns, use a subVI with "Show FP when called" and "Close afterwards when originally closed". (These are VI properties, Windows appearance).
André
André (CLA, CLED)
(3,208 Views)
Try the attached & see if it ll suffice.
- Partha ( CLD until Oct 2027 🙂 )
(3,193 Views)
