How to change the value to name?
Dear all
I need to change value of SMU2, and I hope I can save the result in different file corresponding to different value automatically by the different path. then I met the problem as what I showed in the VI.
I tried to use the "event case structure" but I can't get the result what I want, Is that the right block? and how to get what I want?
Thank you for any help!
Jing
(3,267 Views)
Hi jing,
you can use the "number 2 fractional string" function. See the attached picture.
Mike
(3,257 Views)
Thank you Mike, you are always my SAVIOR!
Jing
(3,248 Views)
Mike is now becoming a savior to lot of people. Smiley Wink
Great work mike Smiley Very Happy
Mathan
(3,244 Views)
Hi jing,
here is another way to make what you want. With this solution you have directly a filename. Smiley Happy
Mike
(3,203 Views)
