How to change time format in the "Write LabView Measurement File" Express VI?
Hey,
Is there a way to change the time format of the x column for the "Write LabView Measurement File" Express VI?
Also, I was wondering if there's a way to change the column headers in the .lvm file?
Thank You,
Molana
(2,748 Views)
Hello Molana,
The Write LabVIEW Measurement File Express VI is designed to be a quick and easy way to start writing data to file. However, this also means that there are limited configuration options. If you are looking for more advanced options the best thing to do is to build your own datalogger using the File I/O VIs or to modify an existing one. I hope this helps!
Best Regards,
Chris J
(2,724 Views)
