How to change tip strip for each cell on multicolumn list or table
I would like to change the tip strip of each cell on multicolumn list or table. Is there any way to do this?
(2,778 Views)
Not statically, but you can do this in code:
That's a method on the left and a property on the right.
I don't know if this will work as you expect (it should change the tip strip, but I don't know if it will appear like you want it to), so you can also implement this yourself by having a string indicator which you show and move around using its properties.
___________________
Try to take over the world!
(2,763 Views)
