How to change width and height of array cell on the front panel programatically
I want to know if it is possible to change width and height of array cell on the front panel programatically? For example I can resize array or cluster cell by going: front panel -> RIght Click to Array indicator -> Size -> Height, Width.
How can I access Height, Width programatically?
(2,683 Views)
You should be able to use a property node to access the array element's properties, which will include its size.
Is that what you mean?
GCentral
(2,671 Views)
