How to cheaply measure low current over time while sourcing a constant voltage?
Hi Rhydo,
you should rather start LabVIEW and look in its help menu…
Message 11 of 12
(601 Views)
Use the Keitley if it meets your requirements. You should easily find the LabVIEW driver for it and you will be ready in a week if you do not know LabVIEW (if you know then it is a matter of hours). With 100nA and a budget of $400 you are going to fail if you do not have experiance in desiging precision instrumentation.
Message 12 of 12
(600 Views)
