How to check for NaN?
Unlike robust statistical software programs, many of the LabVIEW stat functions
and other data manipulation (e.g., 1-D array sort) do not handle missing
values (NaN, for example) correctly. I found a tech support article that
referred to a "primitive IsNaN VI" that can be used to check whether an input
is NaN. Where is this VI? I can't find it in any of the libraries, but since
I don't know how to easily search all the libraries I may be missing it.
(4,458 Views)
Jim,
Right click on the diagram and point at 'comparison' sub-palette. On this
palette you will see 'Not a number / Path / Refnum' primitive.
Jared
"Jim Rathman" wrote:
>>Unlike robust statistical software programs, many of the LabVIEW stat functions>and
other data manipulation (e.g., 1-D array sort) do not handle missing>values
(NaN, for example) correctly. I found a tech support article that>referred
to a "primitive IsNaN VI" that can be used to check whether an input>is NaN.
Where is this VI? I can't find it in any of the libraries, but since>I don't
(4,458 Views)
