How to check if I can get internal output in USB 6210
Hi
I have a NI USB-6210 that I want to use, but when I was trying to work with it, I get the error: device does not have an available internal excitation source.
Is there any way to check if the internal source is working? The self-calibrating and self-testing worked fine.
(1,376 Views)
Accepted by topic author ait116
That device isn't designed to provide excitation to something like a strain gauge, thermistor, or whatever.  It can't do it because it was never meant to, not because something isn't working.
-Kevin P
(1,357 Views)
I'm going to go way out on a limb here and suggest that you may come across device specific information by reading the device user manual. Have you tried that?
(1,348 Views)
Thank you!
(1,299 Views)
Yes, I did. Would not have asked if the answer was there.
(1,319 Views)
It was there.  Well, actually it wasn't,  manuals don't tell you what devices can't do.  It doesn't list "Will not Output Coffee" either.
(1,307 Views)
