How to check if a computer is in the network
i want to send a simple "ping" to a TCP-IP-adress an receive the result if the IP is available.
Is there a easy way to to this in LV or do i have to to it over Start->Run->CMD ?
Thx
(2,844 Views)
Use the System Exec.vi, cmd line ping (your computer name) and parse the standard output for your desired info
Paul
(2,836 Views)
Hello NewOne,
this may help you.
(You don't need the 'local' comparison, it's for personal usage)
Message Edited by GerdW on 10-14-2005 01:19 PM
(2,833 Views)
Works perfect. Thx for the fast help to  GerdW & Pana-Man
(2,820 Views)
