Some people like the fact that you can name things the same. Some even want to be able to have two VIs with the same name in memory at the same time. (Scoping rules to follow in future LabVIEWs.) You can write a small program that lists out the names of all the controls and indicators in a VI using the VI server property nodes. Oh, OK I'll give you an example. (See attached)
Daniel L. Press
PrimeTest Corp.
www.primetest.com
