How to check number of elements available in RT FIFO?
    Without using READ FIFO function is there a way to check the number of elements in RT FIFO? I am looking a function like the get queue status function VI.
    Thanks a lot!
    Tom
(3,434 Views)
Accepted by topic author tom_z
(3,431 Views)
I am having this exact question right now however the link to the document referenced does not give me access.  Is there a better link?
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(3,241 Views)
RT FIFO Read and Write functions have had a "# elements" output since LabVIEW 8.2.  You should be able to utilize that output to determine how many elements are left in the FIFO.  If you have a version of LabVIEW previous to LabVIEW 8.2, you can utilize the attached VI to determine how many elements are left.
Keith M.
(3,230 Views)
