How to check the folder or the files exist in the path
Hi i have to check the folder and the file in the folder is was created or not. For example c:\Abc\123.txt..i want to make sure that there is folder cal Abc and if dont have i need to create tht folder and have to create 123.txt. How to create folder and txt when it not exist? help plz.
(3,038 Views)
The OpenG toolkit has a function 'Create dir if non-existent', you feed this function the folder (c:\abc) and the folder will exist after this piece of code.
Then you can use the native read/write functions to create or open the file.
Ton
My LabVIEW Ideas
(3,036 Views)
Goto Advanced File Functions in the File I/O palette. There are function nodes List Folders and Create Folders. Also, in the File I/O palette, there is a function Open/Create File. Check them out and post back if you have any questions.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,035 Views)
There's also a VI that ships with LabVIEW that does this:
vi.lib\utility\libraryn.llb\Create Directory Recursive.vi
(2,996 Views)
