How to chnage number of bits in every packet of a byte array
Hi I have an array of byte array of 1 and 0s. I would like to make sure every pack of 1 or 0s contains 8 number
I can use this example to explain it better. Lets say I have this array
111111110000000111111100000000
As can be first pack of 0s and the second pack of 1s contain 7 bits. I would like to programaticaaly change it to 8 so the result should be
11111111000000001111111100000000
As can be seen now evey pack of 1s or 0s contains 8 element . Could you please help me on this.A sample code would be great
Many thanks
(2,757 Views)
(2,731 Views)
Reshape array is your friend.Nevermind.  I just realized what you were going for.  Will need to rethink...
(2,716 Views)
One clarification: Can there be two packets of 1's (or 0's) together, for which you need 16 1's, etc., and if so, how do you identify this condition?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(2,706 Views)
Are they always all 1's and/or all 0's?  Do they alternate as in the example?  Why are there missing data?  Is this something that should be fixed before parsing the string?
Bill
CLD
(Mid-Level minion.)
(2,688 Views)
