How to clear controls when operation is finished?
How do I clear controls auotmatically either when I stop running a vi or when I start running one.
(3,066 Views)
Do you want to set them to their default values? If so, you can just use the VI Server like so:
Message Edited by smercurio_fc on 03-12-2007 12:17 PM
(3,061 Views)
Doesn't seem to work. It reinitializes during the ooperation of the vi.
(3,048 Views)
If this does not work then you are probably coding it in wrong.  What is you are trying to do exactly. Do you want to set them to a known value (ie default) or do you want to clear some some string or numeric controls/ indicators to zero or empty.
Here is an example of using the default.
Message Edited by Jhoskins on 03-12-2007 04:20 PM
Joe.
"NOTHING IS EVER EASY"
(3,042 Views)
Got it. Thanks
(3,031 Views)
