How to clear up a string control afer input
Altenbach, thanks for your solution above. It also helped me. Anyway, how can I make the string selected (like hold "Shift" and press "Home" on the keyboard) so that another input can be done immediately without clearing the string. I couldn't find a way of sending keystrokes to a string.
Message 11 of 15
(1,161 Views)
I don't understand what you are trying to do.
You can do filtering "key down?" events (on the control or on the panel), for example to achieve almost anyhtng you want.
Message 12 of 15
(1,159 Views)
You can see the pics below. You might experience it when you input the wrong password in Mac OS login screen. YOu dont need to delete the string to input another because it's automatically highlighted.
Message 13 of 15
(1,142 Views)
Like this.
Set the key focus of the control.  Set the Selection Text to go from 0 to some number equal to or greater than the length of the string.
Message 14 of 15
(1,124 Views)
Thank you RavensFan, it worked. You saved me a lot of time!
Message 15 of 15
(1,113 Views)
