06-01-2016 07:11 AM
I have a cdaq at a remote location which I can connect to How would I remotely clone the system on to a cdaq here?
regards
Simon
06-02-2016
08:18 AM
- last edited on
05-25-2026
03:15 PM
by
Content Cleaner
I am Ed from National Instruments Applications Engineering. If you are referring to the RT OS on the cDAQ 9132, then you can indeed replicate the setup with the Replication and Deployment Utility to create an image of the remote system and then deploy to your local system. This is described in the white paper linked below which also provides the download page for the RAD Utility:
Ed
