How to close a subvi programmatically
I am calling a subvi in my main application.  The front panel opens because I checked the box in VI Properties > Windows Appearance > Show Front Panel When Called.  How can I close it prgrammatically at a time when I want it to dissapear?  BTY, I am using LV 6.1.
Jerome.
Message 1 of 19
(12,185 Views)
There are a few ways of doing that, but first answer yourself this question: should the subvi keep running or finish executing?
If you can have it finish its job, it will or can close by itself (eihter choose dialog style window or check option "close front panel if originally closed").
If the subvi is to keep running, you can hide or minimize its window by using vi server and writing to a front panel state property node. Make sure you save your work often when working with this!
Message 2 of 19
(12,177 Views)
Aart-Jan, thanks for your help.  I prefer the vi to close, but if I could get the front panel to dissapear, that would be great already.  I don't want to check the box "close front panel if originally closed", because I am calling the subvi many times and I want to close it after it has been called many times not necessarily related to its end of execution.
I couldn't find a property node option that would allow me to hide or minimize the window.  What I did it opening a vi reference then connect it to a property node.  What am I missing?
Jerome.
Message 3 of 19
(12,172 Views)
Try the attached VIs.
The Main VI calls/ closes the sub VI by VI Server.
LabVIEW 7.0
Windows set at 1024x768
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 4 of 19
(12,166 Views)
maybe this helps:
Message 5 of 19
(12,161 Views)
Aart-Jan,
Thanks for your help.  I couldn't find the property of FP.State (probably because I am still using LV 6.1) but I tried FP.open and it works fine.  Thanks again for your help.
Jerome.
Message 6 of 19
(12,129 Views)
Hello Ian,
Thanks for your help.  I have LV 6.1 so I can't open your attached files.  However, Aart-Jan's advice did the trick.
Thanks anyway,
Jerome.
Message 7 of 19
(12,128 Views)
I have created an action engine to do this in some of my apps.  Look at this document and create an action engine that will init, open, close, and kill your window.  The closing of the reference when the vi is called by vi server will close the vi and remove it from memory.  Check it out.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
Message 8 of 19
(12,118 Views)
I love utilities and this is a very useful utility. I do wonder why you used a string control instead of an enum, though. And the "command" must be a required input to prevent undesired behaviour.
Message 9 of 19
(12,106 Views)
I use a string out of habit.  Enums are great but I have been using strings for years.  If I am forced to I will 🙂  I typically have a developer error case to handle all misspellings, etc.  I just put this together really quick and didn't properly document it.  Just figured I would contribute.  The main point is to encapsulate this functionality into one vi to allow for flexibility.
BJD1613
Philips Respironics
Message 10 of 19
(12,003 Views)
