How to collect exact time per sample using ARDUINO+LABVIEW
I am using Labview & Arduino to collect some data from a rig. The sensors connections and reading are just fine, but there is something that I just cant achieve.
I am using the Write to Measurement file to save the data collected but I am not getting a time column. I do not want an exact time column, like : 8:51:62,145,
no, what I want is column that starts with 0 ms from the first data collected, like this:
Data
Time  (ms)
Data 1
0
Data 2
200
Data 3
400
Data 4
600
I need to plot a graph data X time, so please help me
(4,100 Views)
Subtract the current timestamp from the starting timestamp - this will give you the relative time in seconds.
(blog)
(4,090 Views)
Also I don't think LIFA or LINX supports reading the hardware timing when samples were taken, so what you'll be doing is assigning a time that is when the sample was received on the Windows side, not when the sample was taken from the DAQ.  This imprecise is usually no big deal but you won't be able to do precise waveform analysis for things like frequency measurement.  Both LIFA and LINX has the firmware source available so it is possible to modify the code to send over the hardware timer of when the samples were taken.
(4,083 Views)
How could I modify the firmware code to obtain the sample timing?
void loop()
// Check for commands from LabVIEW and process them.
checkForCommand();
// Place your custom loop code here (this may slow down communication with LabVIEW)
if(acqMode==1)
sampleContinously();
(4,072 Views)
Would be something like this???
(4,063 Views)
