How to color an svg ?
Hello everyone, I want to color an svg image through Labview. The picture  is a Taiwan map. SVG. Can I color each area individually through Labview?
In Microsoft's WPF development software, I can dynamically modify the color of the area through the style of XAML. Can labview also do it?
thank
(2,370 Views)
Accepted by topic author koukileo
Hi kuokileo,
as SVG files are basically XML files you can easily edit them by using stirng functions!
Search the color tag and change its value…
(2,365 Views)
I got it
What a clever way. Thank you!!
But I will use it in NXG5.1, which does not seem to support XML
(2,354 Views)
@koukileo wrote:
I got it
Which is ironic because a gvi is just an xml document!
Bill
CLD
(Mid-Level minion.)
(2,308 Views)
From a more basic viewpoint, an XML-file is just a text-file.
In order to learn what is necessary to color a  region in your svg I recommend to download an svg-programm like inkscape, edit the svg and see the changes.
Regards, Jens
Kudos are welcome...
(2,299 Views)
