How to combine 3 or more set of 2D array to make a 3D array
Hi all,
I have few sets of 2D array , I want them to group together in a 3D array so each 2D array will be in a different page. Is there a way to do that. I tried reshape array but was not successfull since my understanding of handling array is less. Can you please help me out.(example data is attached)
Ankit G
(2,530 Views)
Accepted by topic author AnkitG
Build Array should do what you want.
Note that I changed the value of the first element in arrays 2 and 3 so you can tell where the data on different pages in appended array came from.
Lynn
(2,526 Views)
Thanks for the solution lynn.
(2,519 Views)
