How to combine different array/cluster sizes in one X-Y graph
I'm working on a project to analyse hysteresis loops and have come up with three X-Y graphs which give me the information I need. However, I would like to be able to overlay the plots on top on one another. They all have the same axes (load and displacement), but different content:
1. "Load-Displacement" is a cluster of two 1D arrays (length is variable depending on the data file - in the dummy file attached it is 6369 points)
2. "Stiffness" is a cluster of two 1D arrays (always 2 points in length)
3. "Rectangles" is a 1D array of a cluster of two 1D arrays (length dependent on the number of rectangles which is determined by the number of times the FOR loop is executed - default is 100)
Can someone point me in the right direction - I'm sure there must be an easy way, but haven't found it in the help file/searches/forums
Many thanks,
Ian
(4,539 Views)
Accepted by topic author ianhaigh
Use Insert Into Array to add the Load-Displacement Curve and the Stiffness Trace to the already existing Rectangle plot array.
Plot the resulting array of clusters and you should get what you want.
(4,533 Views)
Something like this
Tim
GHSP
(4,532 Views)
Thanks for the quick reply,
It hadn't clicked that I could use the Insert Into Array for that purpose!
Cheers,
Ian
(4,525 Views)
