How to combine two arrays: original array and the array of its interpolation values
we get a new array of values after using interpolation function on an array in labview, but how to combine the original array of values and this interpolated set of values into one single array ??
Message 1 of 17
(5,777 Views)
Hi Mahisnair,
maybe you should explain, what you really want to achieve?
You can prepend or append values using BuildArray, you can insert values in between using InsertIntoArray, you can "mix up" values using InterleaveArrays. You really have to say what you need!
Message 2 of 17
(5,763 Views)
build array, interpolate array
Message 3 of 17
(5,758 Views)
Damn, Too Late!
Not sure what you need exactly, need more clarification.
Build Array?
Interleave 1D Array?
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 4 of 17
(5,762 Views)
Post your VI friend. It will be good to debug
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 5 of 17
(5,762 Views)
please run my VI using the input file, in the graph there is shown the an array of values [while dots\line in graph] and its interpolated values[ red in graph]
i need a way to get the original array of values and its interpolated value [array] into a single array.
Message 6 of 17
(5,755 Views)
Hi Mahisnair,
you still not explain what you want to have! How should the data be arranged?
Message 7 of 17
(5,752 Views)
array A = [ 1, 2, 3, 4 ]
array B = [ 1.2, 1.4,  2.2,  2.4,  2.6 , 3.2, 3.4, 3.6, 3.8 ]
i need,
array C = [1, 1.2, 1.4, 2, 2.2, 2.4, 2.6, 3. 3.2, 3.4, 3.6, 3.8, 4 ]
A is the roginal array of values, B is the interpolated values, i need both the values into a single array C
please note tht its not the same number of values to be inserted between  elements of array A to get array C.
Message 8 of 17
(5,750 Views)
Hi Mahisnair,
append using BuildArray, followed by Sort1DArray 😄
Message 9 of 17
(5,746 Views)
in my example that logic holds true, but if you run my VI you can see that i dont have the luxury of sorting to get values in place.
after running my Vi- in the graph, white dots is the array A, red dots is the array B;
please run and see
Message 10 of 17
(5,740 Views)
