How to comminicate between two NI 9871?
Hello, I am now using two cRIO 9205 and each of them has a NI 9871 on it. I built a cable to connect the two port 1 from each card togrthet ( GND ~ GND, TXD+ ~ RTS+, TXD- ~ RTS~). I am trying to send binary files from one card to the other to test how fast the card can be.
Could I ask that how can I make the two cards communicate? I don't know how to write the Labview program.
Thank you very much!!
(2,954 Views)
Hi there,
I don't think your crossover cable is wired correctly, please see this link for details on crossover cable wiring
This module will have to be programmed in FPGA mode, luckily there is a shipping example. Go to the example finder (Help > Find Examples...) and search for '9871' on the Search Tab. You will then see 'NI-987x Serial Loopback' which is an example project with code that achieves your aim.
If you are new to cRIO programming then I recommend NI's RT and FPGA course, see here for details
(2,913 Views)
