How to communicate Micrologix 1400 with labview
We have a machine with 3 Micrologix 1400 PLCs, they are connected through ethernet, it is necessary to collect data from these PLCs,I tried with "ethernet/IP industrial communicatins" VIs (EIC), it was successful for ML 1100, but not with 1400, is there any toolbox like EIC for ML 1400; or is there a way to configure the EIC for the ML 1400?
Thank you
Arturo
(5,199 Views)
Hi Arturo,
I have found this stuff that can be useful! Take a look at it and if it stills not woking we will keep in touch!!
Here is a KB about it: http://digital.ni.com/public.nsf/allkb/79570186202D330E862576740054D8E4?OpenDocument
The only thing is that this KB is in Spanish, if you don´t speak spanish I can help you translating it!
Now here is another forum in Spanish talking about it: http://forums.ni.com/t5/Discusiones-sobre-Productos-NI/Comunicar-Micrologix-1400-con-LabView/m-p/102...
Again I can help you with the language!!
Here is another Forum about it, this one is in English: http://forums.ni.com/t5/Lookout/Can-I-communicate-with-a-Micrologix-1400/m-p/1055546?requireLogin=Fa...
Finally this is a tutorial about how to connect any PLC with LV using OPC Servers!!
http://zone.ni.com/devzone/cda/tut/p/id/7450
I hope this helps!!!
Luis Elias
NI VeriStand and HIL Product Manager
(5,151 Views)
Elias, gracias por el comenario, revise los vínculos y me resulto de utilidad.
Un saludo
(5,121 Views)
is lab view is compatible with DH+ then easily....
or thru modbus  communication.... write massages in plc to send data
(4,782 Views)
