12-09-2009 09:32 PM
jmvrd wrote:
Btw, how can i change the picture(array) set at the strumming VI? im planning to change and modify the said pictures (the one with arrows, and arrows lighted up and down). thanks again.
All you need to do is to create the picture in your favorite program, copy it, then go to the picture ring, select the item you want to replace, right-click on the item and select "Import from clipboard". See Adding Picture Items to Ring Controls in the LabVIEW Help.
12-18-2009 02:01 AM
Just would like to thank you for all the help! i was able to communicate with my board and edit my program thanks to all your help.
Just want to ask some help regarding my C program. Can anyone make this program a lot simpler and will have a shorter lines but the content wont be affected? Right now i have a problem with my microcontroller. It cannot burn the said program because it has many lines and codes in it, so i would want to simplify this program so that the microcontroller would be able to recognize it. Please see attach.
Also, would like to ask, how could you put a delay on DTR program of labview? i would like to add some delay to it so that it wont shift so easily. Please see attach as well. Thanks
12-18-2009 02:41 AM
12-18-2009 11:13 PM
