How to communicate with ADAM6060 module using Labvview ?
Hi, i'm new here, i'm looking to some tutorials to know how to communicate with Adam6060 module using labview.
because i use the Adam utlity and it's impossible to do any thing with the module.
so i need help.
thank you
(3,336 Views)
I have communicated with the adam 4000 series several times, I used visa and sis a simple com read write over com/485 lines.  The communications manual was vary easy, I think there was only a few commands and took a hour or so to produce a driver.  The 6000 series is an ethernet based device but you chould be able to read and write using tcpip calls, you need to get the communications manual as a starting point.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,314 Views)
