How to communicate with FLUKE process calibrator 754??
      I am a newer to Labview, and I want to send commands to and read data from Fluke process calibrator 74X/75X series,. Does anyone know if it is possible ?? Thanks
(4,372 Views)
The easy way is getting instrument driver from here
Certified LabVIEW Developer
GCentral
(4,362 Views)
I found a driver on Fluke's web site that makes the USB connection into a standard com port so you should be able to communicate using the VISA serial functions. I would recommend you test with a program such as putty or the MAX test panels before you write any code.
(4,356 Views)
Yes, I have searched, but no such drivers there.
(4,310 Views)
You'll have to write your own.
(4,291 Views)
