How to communicate with HP 4145B using Labview and NI GPIB-USB-B connection?
Hi folks,
I'm currently trying to communicate with our HP 4145B semiconductor pamaremter analyser.  I do not have experience with GPIB yet. I have installed the NI VISA.
I was wondering if anyone could help with getting me started on how to start communicating with the device using Labview.
I'm not certain where to start.
Kind regards
Rob
(3,151 Views)
Here is a link to the instrument driver. Also on that link is another link "Learning about instrument drivers". That should get you started. You should have MAX (Measurement and Automation Explorer) installed on your computer as well as 488.2. If you open MAX under Devices you should see your GPIB. If your instrument is turned on and you select scan for instruments you should be able to see the 4145B if it is 488.2 compliant.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,142 Views)
