10-28-2010 08:51 AM
Hi, i want to communicate with my OMRON CS1 PLC but i have follwed the instructions to set up this PLC in NI OPC servers but it will not communicate. Tried everything still no joy, can anyone help??
Stu
11-01-2010 08:34 AM
Hi Stu,
Can you run through the steps you have followed thus far in terms of trying to get the PLC set up in NI OPC Servers. What is the exact problem you are facing and what troubleshooting steps have you followed so far?
Best Regards,
Christian Hartshorne
NIUK
11-01-2010 01:14 PM
Hi, been told by OMRON im using a CJ1 PLC not CS1. And i need to use a hub or switch to set a connection to comunicate with the PLC. So will see if this works.
Stu
