How to communicate with SSH using Labview
Hi i am trying to access the server in the university and I was told by technology support center that i had to access the server using an SSH protocol. Is there a way to do this in Labview?
Thank you
Guillermo
(8,901 Views)
I have done this in the past by using a command line version of putty called plink.exe
http://www.chiark.greenend.org.uk/~sgtatham/putty/
call plink.exe with the systemexec.vi using the command line parameters of any ssh commands
- James
Using LV 2012 on Windows 7 64 bit
(8,889 Views)
If you have the Internet Toolkit, you should be able to use the method described by NathanK in this thread.  Otherwise, there are some other options available such as the one James pointed out.
Alex Person
NI-RIO Product Support Engineer
(8,863 Views)
Hi James_R
currently i am using plink to talk to a model, i can access the model successful by using System Exec in labview with command: C:\putty\plink.exe username@ -ssh -pw. but when i try to send some commands to the model with "-m file name", it prompt an alarm: Remote exit code unavailable, have you met this issue before? thanks.
(8,161 Views)
