I have a press force monitoring application which records distance (mm) vs. force (NM) and plots it on a graph.
Before the test is run a master is run and the distance vs. force is recorded. A +/- tolerence is added to the master graph and all tested parts must fall within these limits or the test fails.
I need to compare these two curve based on distance. There is an express VI called in SignalExpress: Analysis: Test and Compare:Limits Test, It does everything I need except I'm unsure if they both can be referenced to the same axis.
I am using 8.5.1 Both curves are formatted into two coloumns Force in one and Distance in the other. Does anyone know how to make sure a curve fails within an upper and lower limit. I need to reference all the data to distance.
