How to compare values from multiples shared variable and find max and min
1-I have around 40 shared variables, i need to compute the max value among them and point out which one, What is the best method to perform the operation ? ( or just use For Loop )
2- I have numeric indicators on my front panel and i need some kind of color change or attention when the value exceeds a specidic number ? any comment or example
(2,782 Views)
Hi Usman,
1. Put all values into an array and use ArrayMinMax. It will give you max/min values as well as their index in the array…
2. Use property nodes of those indicators to set colors depending on the value…
(2,775 Views)
