How to compile for a NI-9144
I can't compile FPGA code for the NI-9144.
I have installed and reinstalled dozens of programs with no solution.
I'm running LabVIEW 2017.0f2
I always get a message saying
"LabVIEW FPGA: The compile worker cannot perform the compilation. The compile worker may be configured incorrectly for this compilation or it may be in an error state."
When I look at the LabVIEW FPGA Compile worker I only see "Vivado 2014.4" installed. I do not understand why I don't see (ISE 14.7)  Should I see this listed in the compile worker? According to Compatible Version to compile for the 9144 I need to have ISE 14.7 installed. I install the program but it does absolutely nothing. I can compile to a 9145 without any issues.
Can someone tell me exactly what I need to install the order to install them.
There are a lot of components that need to be installed.
Engineering - The art of applied creativity  ~Theo Sutton
(2,217 Views)
I now see the ISE 14.7 in my compiler worker.
I restarted the computer and ran the compiler worker as admin.
All appears to be working now.
(2,187 Views)
