How to concatenate string with a numeric control ?
Thankyou.
(4,194 Views)
Can you explain what exactly do you want at output?
like 5(string)+ 5(Numeric)= 55(String)
or 5(string)+ 5(Numeric)= 55(Numeric)
??????????????????????? Smiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,190 Views)
i need to control power supply through Front panel,
for that command is  :VOLn;
Here n reprasent input voltage,
Then,how this command is Send to power supply through Front panel.
Thank you.
(4,186 Views)
Accepted by topic author NSTL
I think I forgot to add semicolon,  what you can do is, drag concatenate function and add semicolon.
Gaurav k
CLD Certified !!!!!
(4,184 Views)
Thank you very much...
(4,179 Views)
IF YOUR PROBLEM IS SOLVED, THEN YOU CAN MARK SOLUTION.
Gaurav k
CLD Certified !!!!!
(4,175 Views)
Its simpler to just use the Format Into String.
(4,157 Views)
