How to configure Aviiva M4 CL 2014 to 4 taps?
I have a system consisting: Atmel Aviiva M4 CL 2014, fg PCIe-1429, PC with MB Asus A8N-SLI.
The camera can run with 4 taps x 30MHz what gives 120 MHZ readout rate but I have only 60MHz. There is no camera configuration file for 4 taps mode, but I changed 2 taps file in the way:
   InterfaceInfo (1429) {
      BitDepth (10)
      NumComponents (1)
      NumPhantomComponents (0)
      ScanType (LineScan)
      Scaling (1)
      DetectPCLK (Yes)
      FastRearm (Yes)
      SynchronizeEnables (No)
      ConfigDelay (0)
      Interlaced (No)
      ControlLinesSource {
         UseDefaultSource (Yes)
         CCSourceLine0 (None, 0)
         CCSourceLine1 (None, 1)
         CCSourceLine2 (None, 2)
         CCSourceLine3 (None, 3)
      TestImageType (None)
      TestImageFrameBlanking (100)
      TestImageLineBlanking (100)
      NumCameraTaps (4)
      NumCameraXZones (1)
      NumCameraTapsPerXZone (4)
      NumCameraYZones (1)
      NumCameraTapsPerYZone (1)
      XZonePixelExtractor (LineEnds)
      YZonePixelExtractor (Top)
      NeedYChip (No)
      NeedZChip (No)
      LVALHighTrue (Yes)
      FVALHighTrue (Yes)
      DVALHighTrue (Yes)
      DVALMode (0)
      AcquisitionBitstream (EP1S20_CL_TCxTx_Base.dat)
      AcquisitionBitstreamCompressed (Yes)
      Tap (0) {
         Position (Normal)
         Start (Left, Top)
   Pattern {
      Action (PG) {
         Line (0) {
            Start (High)
         Line (1) {
            Start (High)
         Line (2) {
            Start (High)
         Line (3) {
            Start (High)
         Line (4) {
            Start (High)
         Line (5) {
            Start (High)
         Line (6) {
            Start (High)
         Line (7) {
            Start (High)
         Clock (0x78)
         RepeatSource (Fixed, 100)
(...) attributes, reset params etc.
Can anyone help me to configure it to 4 taps correctly?
(2,587 Views)
Hello bajer,
Thank you for contacting National Instruments.  I noticed that this exact same issue is already being discussed in the following forum:
http://forums.ni.com/ni/board/message?board.id=200&message.id=10734
Since further progression has already been made there, I would like to continue working with that forum if you don't mind.  Please refer to that one for any new posts.
Mike T
(2,575 Views)
