How to configure CJC on USB-9211(cRIO-9211)
I have a new USB-9211 (cRIO-9211 with carrier) and am using LabView 7.1 to create a DAQ application.  When using the DAQ assistant I configure 4 K-type thermocople channels and set the options therein.  On the option for CJC Source, the options are: Built in, Constant, Channel.  In MAX it shows the CJC as a seperate channel, presumably a semiconductor type temperature device, but in DAQ Assistant it doesn't show this channel.  So, should I choose the "Built in" option for CJC compensation, or is there another way to apply the CJC compensation?
Ed
(2,637 Views)
Continued here.
Ryan Verret
Product Marketing Engineer
Signal Generators
(2,625 Views)
