How to configure Keithly switch 7700?
I use Keithly multimeter 2700 plus switch 7700. I wonder which vi in the drivers supplied by the company can configure the source to "slot 1 7700"?
Thanks!
George
(3,158 Views)
Hi George,
the slot / channel is specified with channel-number.
Find attached a part of kei2700.llb, where you can specify the channel... have a look to sub.vi's, how
the channels are switched.
Hope this helps
regards
wha
(3,158 Views)
Thank you for your very good example!
It can work well one channel each time. Could you please tell me how to let it work in multichannels? When I use 101:103 in the channel list, it doesn't work(display overflow in the device).
George
(3,158 Views)
Hi George,
I have used the attached example for scanning from a channel-list.
Have a look - I think, it is what you are looking for.
regards
wha
(3,158 Views)
Hi Wha,
Thank you for your help!
The scan function can work well now.
George
(3,158 Views)
nice to hear .....
wha
(3,158 Views)
