How to configure SR630 drivers to scan multiple channels and export all data into Excel
Hi, I am new to Labview programming. I am trying to program a SR630 16 Channel Thermocouple Reader to scan multiple channels and output the data into Excel. The driver I downloaded from NI contains a SR630 Example-Scan.VI that scans only one channel and outputs one line of result. How do I modify the drivers to scan multiple channels and export all the data to Excel?
I bypassed the SR630 buffer download by inserting a While loop with a Stop button and a 30 second timer delay, which encloses five Read Channel Measure.VIs, one for each channel I want to measure over time. The values were feed into an array and transferred to Excel using Write to Spreadsheet File.VI. Thi
s works except the programs seems to drop the GPIB address after the 7th or 8th measurement and I obtain an error code: -1073807339. The scanning rate was only every 30 seconds, quite slow. I also have frequent problems terminating the GPIB address from the last run even when I run SR630 Close.VI separately.
I am runing on a Dell Latitude CPt laptop, 600 Mhz Cpu, and a newly purchased PCMCIA-GPIB card from National Instruments.
Any suggestions on how to solve these problems would be greatly appreciated. I need to solve it by next Tuesday because I need it for my business trip. Thank you very much. David Ching
(2,897 Views)
__________________________________________
Hi David,
You may want to post your query in the 'LabVIEW General' section of the forum. This particular forum is for issues relating to the Datalogging and Supervisory Control Module of LabVIEW.. yes, it's kinda misleading!
Good luck!
Khalid 🙂
(2,897 Views)
