How to configure a multi module SCXI attached to PXI
We have a PXI-1002. It interfaces to an SCXI-1000 attached to PXI through PXI-6040E. SCXI has 4 SCXI-1102 cards with 2 TBX-1303 and 2 SCXI-1303 Terminal blocks. The config worked for the 1st module but I'm getting errors for the other modules. How do you configure all the channels?
(2,605 Views)
Greetings,
Which errors are you receiving? Are you receiving these errors in LabVIEW or Measurement & Automation Explorer (MAX)? If you are receiving these errors in LabVIEW, are you able to successfully test your SCXI-1102s in MAX? One last question, are you using Virtual Channels or SCXI Channel Strings?
Spencer S.
(2,605 Views)
