How to configure inputs to ReadDirectoryChangesW
Hi all,
I'm trying to make a Watched Folder program using the Windows API function ReadDirectoryChangesW.
Attached is a test program which uses CreateFileA to open a handle to a directory, passes the handle to ReadDirectoryChangesW which waits for a change in the directory, and then closes the handle with CloseHandle.
The test performs correctly, in that a handle is created and ReadDirectoryChangesW does wait for a change to the watched path, but I can't get any information about the change from the File_Notify_Information structure that is supposed to contain the changed path.
If we can get this working, it could serve as a good example for how to configure Call Library Function Node for more complex API's.
I think I'm close, but I haven't been able to sort out the finer points of passing structs from LV to Windows API functions.
Can you see what I'm doing wrong?
Victor
(4,834 Views)
Heh,
I actually had myself convinced that ReadDirectoryChangesW was the best way to go about implementing a watched folder routine.
In actuality, there is something called .NET that does a lot of nifty crap.
I was fortunate to stumble upon a post by  Jarrod S. where he included sample code using the .NET class FileSystemWatcher.
Now all I have to do is figure out how to (whether) it can be used to watch a subtree and not just a target directory.
Eram Herman also posted his solution in the NI Example Code repository here.
What a relief!
Hopefully I'll figure out how to watch a subtree, when I do, I'll post code on this thread.
Cheers,
Victor
(4,811 Views)
Wensu wrote:
Hi all,
There was quite a bit wrong with it. I fixed it and cleaned it up but didn't test anything so far.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,801 Views)
Hello Rolf,
Thank you for your effort in implementing this function.  I see that my understanding of how to prepare the File_Notify_Information buffer was flawed.   Your solution for reading out the content of this buffer will take some study.
Gratefully,
Victor
(4,794 Views)
Hi Rolf,
The code works beautifully.  Though I noticed that a decrement by 1 out of WideCharToMultiByte was causing the last character of the pathname to be omitted.  Removing the decrement resulted in the entire pathname being returned.
Thanks again,
Victor
(4,790 Views)
