How to configure the call library node to call th function (GetLPTAddress)from a dll library. This function is suppose to return the parrell port address but I get zero all the time.
This is an I2C application. I am currently automating a test station for a power amplifier and would like to call functions
from the I2C library using Labview 5.1
Thank you
Terry
(2,602 Views)
Thank you
Terry
There is not enough data to help you here. What I2C library, what DLL, some documentation or at least header files for your DLL, your VIs you have created and such would be the least one would need to possibly help you.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,596 Views)
