How to connect FPGA IO to Web Service?
I currently have this project Structure.
but when I try to add the LED towards the Process.vi,, it doesnt work.
How do we connect the LED / GPIO towards the Process.vi which is inside webservice?
(3,059 Views)
Hi wavepacket,
you can't drop the I/O-node on a blockdiagram which isn't executete on the fpga. You will need to create one separate vi for the I/O-Communication and compile it for the fpga. At least something like this:
After compiling you can access your I/O via the fpga interface. There you need at least something like this:
And please spend some time cleaning your blockdiagram.
Kind regards,
skusie
(3,054 Views)
