How to connect a linear encoder with ni 6008?
I would like to connect a linear encoder using ni 6008 but i don't know how to do it.
I know that ni 6008 has one PFI channel.
Can i use other digital channel in combination with the PFI to connect the encoder?
Thank you
Francisco
(3,396 Views)
Hi Francisco,
connecting is one problem - the other (and more important) one is analyzing the signals…
The USB6008 has only one high-speed PFI, all those other DIs are only software-timed and so just capable of ~100Hz sample rate. When your encoder is rather slow (or only outputs a low amount of pulses in relation to movement) you could use the AI pins to read the signal (capable of 10kS/s in sum) - with the disadvantage of doing the signal analysis on your own…
(3,394 Views)
Thank you for your quick replay!!!!
What about using a Ni USB 6210?
Regards, Francisco
(3,377 Views)
Hi Francisco,
as the manual explains you could use that device to measure with quadrature encoders…
(3,372 Views)
Thank you!
(3,352 Views)
