How to connect external device with labview DAQ using parallel port?
i would like to know as to how one can connect an external device using a parallel port for DAQ?
RK
(2,977 Views)
There have been a number of threads discussing using the parallel port. One of the resent ones, having to do with LabVIEW 8.2 may be found at :http://forums.ni.com/ni/board/message?board.id=170&message.id=254900&requireLogin=False
A search on "parallel" in the discussion forums will return a log of links.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,972 Views)
